MRS911
Apr 16, 2020Guide
open ports on xr500
hello i want ask about open ports on xr500 for ps4 , i have bad experience with dmz :( so i want try to open ports but i dont know which setting i use .
Netduma-Fraser
Apr 16, 2020NetDuma Partner
Firstly what is your physical setup? UPnP should be able to open the ports without using the DMZ or port forwarding. How are you determining the NAT type?
