MRS911
Apr 16, 2020Guide
open ports on xr500
hello i want ask about open ports on xr500 for ps4 , i have bad experience with dmz :( so i want try to open ports but i dont know which setting i use .
Netduma-Fraser
Apr 16, 2020NetDuma Partner
Firstly what is your physical setup? UPnP should be able to open the ports without using the DMZ or port forwarding. How are you determining the NAT type?
MRS911
Apr 16, 2020Guide
I used bridge mode from ISP router ,,
I didn’t find upnp to open the ports well, because I tried that with cod:MW game and it appears to me that Nat modraete , UPNP only open one ports 3659 UDP !!
If i enabled DMZ the NAT is open but i have bad experience with it .
so now i will try to open ports but i dont know how ??
- Netduma-FraserApr 16, 2020NetDuma PartnerIf you disable the Geo-Filter before turning on the console does it appear open? Sometimes the Geo-Filter can cause a misreading.
- MRS911Apr 16, 2020Guide
no is still modraete
