MRS911
Apr 16, 2020Guide
open ports on xr500
hello i want ask about open ports on xr500 for ps4 , i have bad experience with dmz :( so i want try to open ports but i dont know which setting i use .
MRS911
Apr 16, 2020Guide
I used bridge mode from ISP router ,,
I didn’t find upnp to open the ports well, because I tried that with cod:MW game and it appears to me that Nat modraete , UPNP only open one ports 3659 UDP !!
If i enabled DMZ the NAT is open but i have bad experience with it .
so now i will try to open ports but i dont know how ??
Netduma-Fraser
Apr 16, 2020NetDuma Partner
If you disable the Geo-Filter before turning on the console does it appear open? Sometimes the Geo-Filter can cause a misreading.
