MRS911
Apr 16, 2020Guide
open ports on xr500
hello i want ask about open ports on xr500 for ps4 , i have bad experience with dmz :( so i want try to open ports but i dont know which setting i use .
Apr 16, 2020Guru - Experienced User
Are you sure the ISP modem is fully bridged? The Internet WAN port address will show a ##.##.###.### kind of address if it's fully bridged.
This a PC or game console?
What is the port being seen and used by the console if you have a game console. It should be 3074.
Do not use DMZ for your game device. uPnP is only needed. If you only have 1 PC or gameconsole and NAT is single at the XR router and the modem is fully bridged, OPEN NAT should be seen in the game and xbox networking settings.
- MRS911Apr 16, 2020Guide
my ISP router model huawei HG8245Q
actully i dont know if bridged with ISP router well , he give me public ip and its work with PPPOE in xr500 ,, but maybe need some settings with bridge mode from isp router .
there is only one port i see on ps4 IP in UPNP : 3659 UDP !!
if i used UPNP the NAT with call of duty:MW game on ps4 is moderate
- Netduma-FraserApr 16, 2020NetDuma PartnerIn WAN Settings switch NAT from Secure to Open, does that fix it?
yes give me open>> i tried before but UPNP is still open one port 3659 UDP !? im not feel good with that in game >>
i think need more ports to open it
which best way to open port by portforwarding or triggering port ?
- FURRYe38Apr 16, 2020Guru - Experienced User
This is where you need to focus:
https://support.huawei.com/enterprise/en/access-network/echolife-hg8245q-pid-20981216This is a full on ONT and built in router and wifi. You need to do try a couple of things:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Make sure the ISP can do this with you.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.Do you see OPEN NAT on your consoles networking status?
IF you have PS then the port it's using is correct.
If you get OPEN NAT on the PS networing status and in MW with NAT Filter set to OPEN and uPNP enabled, this is all you need if you got option #1 configured on the modem.
- MRS911Apr 29, 2020Guide
After many experiences I have done to find out which is better
with bridge mode the UPNP not working very well only open one port .
without bridge mode i see the UPNP working great and open many ports that needed in game
so now im using xr500 without bridge mode and i enabled dmz from isp router and put ip ps4 in xr500 with DMZ and enabled open nat from nat filtring .
i dont know why bridge mode not working with my connection ??
