ItsMeDan
Dec 15, 2019Guide
Open VPN max of 20Mmps when using router.
Hi there, If anyone is able to offer some suggestions, when using OpenVPN software on a client machine I get nearly proper speeds 90Mbps, when using the OpenVPN profile on the XR500 the max speed...
- Dec 15, 2019Hi Dan, yes the VPN will be slower when using it through the router. However, due to the Hybrid nature of the VPN you can apply the VPN directly to certain applications/services so that other applications/services on your devices are not behind the VPN and therefore don't get slowed down. So if you're just wanting to VPN a game for example then you can do that with plenty of bandwidth to spare and the rest of the PC can use high bandwidth activities etc.
Netduma-Fraser
Dec 15, 2019NetDuma Partner
