grdmstr75
Jun 12, 2022Aspirant
open vpn with Xr500 netgear router - setup help
Hello, I have been trying to find a free open vpn that i can use to access my home network outside but also use vpn at home to protect the connection line. the router i have is a net-gear xr500 gam...
grdmstr75
ok thanks that worked for the setup on my android phone i was able to connect to the VPN and use my internet connection from 4g.. however how can i access my internal LAN computers ? from my phone , how do i access my PC's behind the netgear router what setting do i need to change or update DMZ ?
Netduma-Fraser
Jun 12, 2022NetDuma Partner
I don't think that's anything on the router side, you'd need to setup Network Share I believe on a PC and then it might work but I don't think that is the main purpose of it so you might need to try a different solution
- grdmstr75Jun 12, 2022Aspirant
what is the main purpose ??
- Netduma-LiamJun 13, 2022NetDuma Partner
What about them exactly are you looking to access? Their files etc? If so then Fraser's above suggestion will work. The purpose is to access your home network securely from outside of it.
- grdmstr75Jun 14, 2022Aspirant
correct but how do i access other computers behind the router with my android phone after i connect the openvpn app to my home network ?
