colieville
Dec 28, 2019Aspirant
Opening Port for Arlo
We've recently purchased an Arlo security system. Unfortunately, it appears as though the Arlo system won't stay connected to the router. After mulitple conversations with Arlo and Netgear, I've di...
colieville
It is connected via ethernet cable. I'm hoping it is a defective Arlo hub and a replacement will correct the issue.
colieville
Dec 31, 2019Aspirant
It is not a defective Arlo hub. Got the replacement today and same issues...
- Netduma_AlexJan 02, 2020NetDuma Partner
Try disabling QoS completely by openining the Anti-Bufferbloat side menu and choosing Disable QoS.
