MatthewH123
Jan 05, 2020Follower
OpenVPN configuration
Hi, recently purchased an XR500, and was trying to set up the OpenVPN server it is able to connect successfully but I am unable to access certain local resources (local web pages running on a local m...
Flix2013
Jan 28, 2020Aspirant
Hey did you get a solution I have the same problem thx
- Netduma-FraserJan 28, 2020NetDuma PartnerHave you tried what I've suggested above?
- Flix2013Jan 28, 2020Aspirant
what i have don so far i Setup a Dynamic DNS With no ip Then I activated the VPN Setting an Downloaden the certifikation file an instaled it on Open VPN Client connect. After i Saw your Post i changed the Port to use and renewed the certification file. Tried do Connection again it says im conected but i still cant Connect to the Server just router. Sorry for Wasting your time but thx for the Helpđ
I cant Change between tun tap but between tcp and udp
- Netduma-FraserJan 28, 2020NetDuma PartnerWhat server are you trying to connect to? Could you explain what the aim of using the VPN service is and we can see where to go from there.
