Munka777
Dec 01, 2018Aspirant
Optimal WAN settings for XR500?
Hey, I’ve been testing some settings recently just trying to get the settings as good as possible then not touch them. I play black ops 4 and was wondering what changes I could make to the WAN setting...
Munka777
Dec 05, 2018Aspirant
Thanks for the reply i have applied those settings, would you recomend mw putting my PS4 in DMZ or not? and would you recomend disabling UPnP whilst using DMZ? Thanks
Netduma-Fraser
Dec 05, 2018NetDuma Partner
If you have an open NAT then no need. If you don't then yes you could do that. Leave it enabled as other devices may need ports opened for them, if any conflicts occur you can disable UPnP.
