drgentz1
Nov 19, 2023Tutor
ORBI 970 series and XR500
Hello, have the Orbi 970 and still want to use the DUMA OS from my XR500. Can I use the XR 500 as an extender or additional router on my network. I have tried a couple different thing and get it to...
- Nov 20, 2023
You can try to use same SSID name and PW as what you have on the Orbi however may cause problems.
You'll need to ensure channels used on the XR and Orbi are far appart.
You might try this, setup the XR as a 2ndary router and turn OFF the wifi radios on the XR router and just connect the wired PCs and any gaming consoles to the router via ethernet connection. Any wifi devices, let the Orbi system handle that.
Nov 19, 2023Guru - Experienced User
You can either run the XR500 in router mode and use the RBRs DMZ for the XR500 while in router mode or configure the XR500 router for AP Mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
For the XR500 to work with the RBR while the XR is in AP mode, configure the XR default IP address to 192.168.0.1. The XRs and RBR default is 192.168.1.1 and two routers can't be on same network with same IP address, So just a minor change to the XR default address will fix that.
Netduma-Fraser
Nov 19, 2023NetDuma Partner
As above but keep in mind that putting the XR500 in AP mode will prevent you using its features
