drgentz1
Nov 19, 2023Tutor
ORBI 970 series and XR500
Hello, have the Orbi 970 and still want to use the DUMA OS from my XR500. Can I use the XR 500 as an extender or additional router on my network. I have tried a couple different thing and get it to...
- Nov 20, 2023
You can try to use same SSID name and PW as what you have on the Orbi however may cause problems.
You'll need to ensure channels used on the XR and Orbi are far appart.
You might try this, setup the XR as a 2ndary router and turn OFF the wifi radios on the XR router and just connect the wired PCs and any gaming consoles to the router via ethernet connection. Any wifi devices, let the Orbi system handle that.
drgentz1
Nov 19, 2023Tutor
Yes been having issues with that IP figures I forget something always have my PL 100p as 3 the ex7700 as 4 and forget to change the XR...so I see I can't use DumaOS but if I leave it in router mode and just chagr the ip will this work efficiently? Wondering if on the wifi side do I need to change any SSID? Was told I can leave the same and that devices will connect to closest/strongest signals??
Nov 20, 2023Guru - Experienced User
