jp_otoole12
Aug 23, 2020Aspirant
packet burst and lag xr300 but not with my isps router help
Hi im new to gaming routers i brought the xr300 about two months ago and im finding my isps router dosnt give me packet burst or lag but when i connect the xr300 i get alot of lag packet burst while...
Netduma-Fraser
Aug 23, 2020NetDuma Partner
First of all I would highly recommend going through our optimal settings guides: http://support.netduma.com/support/solutions/folders/16000090646 as they'll give you settings to use and help you understand how the router works. What is your average ping shown by the Geo-Filter? Are you using QoS?
- jp_otoole12Aug 23, 2020Aspirant
Thanks for speedy responce ping 25 and yes im using qos
the problem is lag when connected to xr300 wired,But when i take the xr300 off
and use the hub3 i dont lag at all.not just happening in one just game awell
- Netduma-FraserAug 23, 2020NetDuma PartnerThat is a pretty good ping. Do my above suggestion so you eliminate the lag as much as possible.
ive been trying everything in the guides for a month now nothing helps
thanks again
