fdeisgreat
Feb 29, 2020Tutor
packet loss and headaches
to verify, i have the r6700v3 but apparently that isnt a valid option. anyways, i got this nighthawk router a while back and i havent used it in about a year due to the packet loss and latency is...
- Mar 01, 2020
Not all manufacturer's bridge mode works properly. Try the modem in modem/router mode and put the netgear in AP mode. See if that works.
fdeisgreat
Mar 01, 2020Tutor
ok so i put the nighthawk in AP mode and now the internet is working while my pc is plugged into the nighthawk. Speedtest shows my download at 100mbps when i pay for 1000mbps. removing the ethernet from the nighthawk to the docsis keeps internet, however im also slowed to 100mbps
Mar 01, 2020Guru - Experienced User
check your cable.
Also, check the qos on the modem/router combo device. The netgear in AP mode lets the modem/router handle everything.
- fdeisgreatMar 01, 2020Tutor
cables are all snug as a bug, the modem i was provided with has no qos settings also.
- plemansMar 01, 2020Guru - Experienced User
Check to make sure your cables are cat5e, cat6 or greater.
not just that they're seated.
What speed do you get directly off the modem/router?
to be honest i have no clue. My dad set up the wires all around years ago. We just dug through a box of old wires and found an ethernet cord to run through the floor to the basement into my xbox.
Also its weird, because on my pc testing through ethernet on speedtest.net or my isps speedtest yields about the same dl rate (92-95mbps)
however going into xbox's network settings and running a statistics test it says my download is 555mbps with 0% packet loss and 40 ping (plugged into nighthawk) havent tried docsis but maybe my pc's network part doesnt support 1000mbps?
hey i just looked at the wire and it says cat5 not cat5e. Should i probably invest in cat6/higher?
- plemansMar 01, 2020Guru - Experienced UserProbably a good idea. Also check the port on the computer to make sure its gigabit
do i have to look at the back? or can I see through the windows settings/software?
im gonna run speedtests on every port i can, by the way, i bought this cord, i saw there was a video on how to strip them and connect your own connectors (the whole in the floor isnt big enough for those giant connector ends.)
https://www.amazon.com/gp/product/B00BR3I0F6/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
this is fine right? ^
sorry for all the replies, but i just noticed i have only one ethernet port.
