fdeisgreat
Feb 29, 2020Tutor
packet loss and headaches
to verify, i have the r6700v3 but apparently that isnt a valid option. anyways, i got this nighthawk router a while back and i havent used it in about a year due to the packet loss and latency is...
- Mar 01, 2020
Not all manufacturer's bridge mode works properly. Try the modem in modem/router mode and put the netgear in AP mode. See if that works.
Mar 01, 2020Guru - Experienced User
Probably a good idea. Also check the port on the computer to make sure its gigabit
fdeisgreat
Mar 01, 2020Tutor
im gonna run speedtests on every port i can, by the way, i bought this cord, i saw there was a video on how to strip them and connect your own connectors (the whole in the floor isnt big enough for those giant connector ends.)
https://www.amazon.com/gp/product/B00BR3I0F6/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
this is fine right? ^
