fdeisgreat
Feb 29, 2020Tutor
packet loss and headaches
to verify, i have the r6700v3 but apparently that isnt a valid option. anyways, i got this nighthawk router a while back and i havent used it in about a year due to the packet loss and latency is...
- Mar 01, 2020
Not all manufacturer's bridge mode works properly. Try the modem in modem/router mode and put the netgear in AP mode. See if that works.
Mar 01, 2020Guru - Experienced User
fdeisgreat
Mar 02, 2020Tutor
im gonna mark this as the solution because it seems to have fixed my packet loss. Im still at a loss of why my pc is speedtesting at 100, but xbox is saying its well over that so it's probably just my pc's ethernet port that's limited.
I appreciate all the help you've given me, thank you.
