xbayx650
Feb 26, 2019Aspirant
Packet Loss on XR700 since latest update
I have the XR700 and since the 1.0.1.8 update, I have been getting consistent packet loss while playing fortnite.
This is what I have tried
- packet loss occurs both on WiFi and Ethernet...
Feb 26, 2019Guru - Experienced User
Are you testing with ALL other devcies disconnected from the router?
Was a factory reset and setup from scratch performed after 1.8 was applied?
Try reverting back to v20 as others mentioned this seems to be the most stable.
- Netduma-FraserFeb 26, 2019NetDuma PartnerIs it ONLY on the game or do you experience issues with other games or devices using the internet etc?
Disable Traffic Prioritization, do you see the same issue?- xbayx650Feb 26, 2019Aspiranti have a Nintendo switch as well, there is some lag but I suspect it’s Nintendo online system.
I have tried disabling traffic prioritization and issue still occurs.
But the fact it doesn’t have issue with my old router.
- xbayx650Feb 26, 2019AspirantInternet provider: Cable 1000mbs down / 30 upload
Router: NETGEAR Nighthawk Pro Gaming XR700
Modem: NETGEAR Gigabit Cable Modem (32x8) DOCSIS 3.1 CM1000-1AZNAS
