xbayx650
Feb 26, 2019Aspirant
Packet Loss on XR700 since latest update
I have the XR700 and since the 1.0.1.8 update, I have been getting consistent packet loss while playing fortnite.
This is what I have tried
- packet loss occurs both on WiFi and Ethernet...
Feb 26, 2019Guru - Experienced User
Are you testing with ALL other devcies disconnected from the router?
Was a factory reset and setup from scratch performed after 1.8 was applied?
Try reverting back to v20 as others mentioned this seems to be the most stable.
Netduma-Fraser
Feb 26, 2019NetDuma Partner
Is it ONLY on the game or do you experience issues with other games or devices using the internet etc?
Disable Traffic Prioritization, do you see the same issue?
- xbayx650Feb 26, 2019Aspiranti have a Nintendo switch as well, there is some lag but I suspect it’s Nintendo online system.
I have tried disabling traffic prioritization and issue still occurs.
But the fact it doesn’t have issue with my old router.
