xbayx650
Feb 26, 2019Aspirant
Packet Loss on XR700 since latest update
I have the XR700 and since the 1.0.1.8 update, I have been getting consistent packet loss while playing fortnite.
This is what I have tried
- packet loss occurs both on WiFi and Ethernet...
Feb 26, 2019Guru - Experienced User
Are you testing with ALL other devcies disconnected from the router?
Was a factory reset and setup from scratch performed after 1.8 was applied?
Try reverting back to v20 as others mentioned this seems to be the most stable.
xbayx650
Internet provider: Cable 1000mbs down / 30 upload
Router: NETGEAR Nighthawk Pro Gaming XR700
Modem: NETGEAR Gigabit Cable Modem (32x8) DOCSIS 3.1 CM1000-1AZNAS
