xbayx650
Feb 26, 2019Aspirant
Packet Loss on XR700 since latest update
I have the XR700 and since the 1.0.1.8 update, I have been getting consistent packet loss while playing fortnite.
This is what I have tried
- packet loss occurs both on WiFi and Ethernet...
Feb 26, 2019Guru - Experienced User
Was a factory reset performed then setup from scratch when v40 was applied?
Try reverting back to v20 as others mentioned this seems to be the most stable.
Netduma-Fraser
Feb 26, 2019NetDuma Partner
Disable QoS completely under Anti-Bufferbloat's options, does that resolve it?
