DirtySZN
Jul 24, 2020Aspirant
Packet Loss/Lag continues while gaming
So I have been writing posts on Reddit over the course of the last few months as I have been having lag issues/packet loss/ISP problems... As I thought it was my router/modem initially causing th...
- Aug 04, 2020defiled669 you're on beta firmware, there will be bugs, that is to be expected.
DirtySZN okay that's very interesting, the only other way would be to talk to your ISP and see if they can help adjust your routing for better ping. They will likely be hesitant so perhaps you could say something like your a content creator and that this directly impacts your job - saying it affects your work sometimes prompts them to do something when they otherwise wouldn't.
Netduma-Fraser
Jul 25, 2020NetDuma Partner
Thank you for the extensive write up. Could you get the IP of the Fortnite server from the Geo-Filter please and then run a PingPlotter test and post a screenshot here of the results?
