DirtySZN
Jul 25, 2020Aspirant
Packet Loss/Lag continues while gaming
So I have been writing posts on Reddit over the course of the last few months as I have been having lag issues/packet loss/ISP problems... As I thought it was my router/modem initially causing th...
- Aug 04, 2020defiled669 you're on beta firmware, there will be bugs, that is to be expected.
DirtySZN okay that's very interesting, the only other way would be to talk to your ISP and see if they can help adjust your routing for better ping. They will likely be hesitant so perhaps you could say something like your a content creator and that this directly impacts your job - saying it affects your work sometimes prompts them to do something when they otherwise wouldn't.
Netduma-Fraser
Jul 26, 2020NetDuma Partner
Thank you for that, could you also try playing directly connected to the modem as well and see if you experience the same issues?
DirtySZN
Jul 26, 2020Aspirant
This image is the CoD server plot connected only to the Modem -
