DirtySZN
Jul 24, 2020Aspirant
Packet Loss/Lag continues while gaming
So I have been writing posts on Reddit over the course of the last few months as I have been having lag issues/packet loss/ISP problems... As I thought it was my router/modem initially causing th...
- Aug 04, 2020defiled669 you're on beta firmware, there will be bugs, that is to be expected.
DirtySZN okay that's very interesting, the only other way would be to talk to your ISP and see if they can help adjust your routing for better ping. They will likely be hesitant so perhaps you could say something like your a content creator and that this directly impacts your job - saying it affects your work sometimes prompts them to do something when they otherwise wouldn't.
defiled669
Jul 27, 2020Apprentice
the qos is not working along with the bandwidth allocation. geo filters not finding servers. i ran several speed test on my xbox yesterday trying to qos my bandwidth and every time the download and up load would never be adjusted i even set my bandwidth to 10, out of 1000 mbps and still every test came back 800 plus mbps. also noticed that download speed is constricted on the benchmark test can never get it to go past 450 and upload past 750. so these new apps are great to have but only if they are working properly. another thing i noticed was that benchmark test does not account for qos or bandwith allocation. so its something flawed heavily with qos and bandwidth allocation. geo filter not pinging servers in ping the host. and would suggest on ping heat map an allow and block server option
