DirtySZN
Jul 24, 2020Aspirant
Packet Loss/Lag continues while gaming
So I have been writing posts on Reddit over the course of the last few months as I have been having lag issues/packet loss/ISP problems... As I thought it was my router/modem initially causing th...
- Aug 04, 2020defiled669 you're on beta firmware, there will be bugs, that is to be expected.
DirtySZN okay that's very interesting, the only other way would be to talk to your ISP and see if they can help adjust your routing for better ping. They will likely be hesitant so perhaps you could say something like your a content creator and that this directly impacts your job - saying it affects your work sometimes prompts them to do something when they otherwise wouldn't.
DirtySZN
Aug 01, 2020Aspirant
So just an update as of this morning(8/1/2020). As I was playing Fortnite last night, there was an unfortunate drastic amount of packet loss once again... Since the other night it slowly has gotten worse again and I am very disappointed honestly.
I have tried all numbers 1-4 like you asked. With number 4, I no longer have ExitLag as it was a 3 day free trial(will only purchase it if that is for sure going to help me out).
I am really confused on where the problem may lie here...
Netduma-Fraser
Aug 02, 2020NetDuma Partner
Do you have specific results for each test so we can see what was better and so we can see where the issue may lie?
- defiled669Aug 04, 2020Apprentice
outcome was always the same because qos and anti bufferbloat and geofilter are not working, so i had to revert to old os to play games it was so terrible
waiting for supposed update this week
- DirtySZNAug 04, 2020Aspirant
I do not have any results to go off of. However, I did purchase a month of ExitLag and it seems to have solved the issue over the last 2-3 days - I have experienced very little to no packet loss while using it.
My only question would be is there any way I can fix the routing without paying for ExitLag or is that something too far out of my control?
