DirtySZN
Jul 24, 2020Aspirant
Packet Loss/Lag continues while gaming
So I have been writing posts on Reddit over the course of the last few months as I have been having lag issues/packet loss/ISP problems... As I thought it was my router/modem initially causing th...
- Aug 04, 2020defiled669 you're on beta firmware, there will be bugs, that is to be expected.
DirtySZN okay that's very interesting, the only other way would be to talk to your ISP and see if they can help adjust your routing for better ping. They will likely be hesitant so perhaps you could say something like your a content creator and that this directly impacts your job - saying it affects your work sometimes prompts them to do something when they otherwise wouldn't.
Netduma-Fraser
Aug 02, 2020NetDuma Partner
Do you have specific results for each test so we can see what was better and so we can see where the issue may lie?
defiled669
Aug 04, 2020Apprentice
outcome was always the same because qos and anti bufferbloat and geofilter are not working, so i had to revert to old os to play games it was so terrible
- defiled669Aug 04, 2020Apprentice
waiting for supposed update this week
- DirtySZNAug 04, 2020Aspirant
I do not have any results to go off of. However, I did purchase a month of ExitLag and it seems to have solved the issue over the last 2-3 days - I have experienced very little to no packet loss while using it.
My only question would be is there any way I can fix the routing without paying for ExitLag or is that something too far out of my control?
- Netduma-FraserAug 04, 2020NetDuma Partnerdefiled669 you're on beta firmware, there will be bugs, that is to be expected.
DirtySZN okay that's very interesting, the only other way would be to talk to your ISP and see if they can help adjust your routing for better ping. They will likely be hesitant so perhaps you could say something like your a content creator and that this directly impacts your job - saying it affects your work sometimes prompts them to do something when they otherwise wouldn't. - defiled669Aug 05, 2020Apprentice
i got a great ping, and the only problem im having on this beta is nothing works at all, had to reinstall old version, waiting for update that was supposed to come this week if i read frazzer right
- Netduma-FraserAug 05, 2020NetDuma PartnerNo need to keep posting in non beta topics, you will get a new build soon yes. Please post any issues you have just in case we're not aware of them.
