DirtySZN
Jul 25, 2020Aspirant
Packet Loss/Lag continues while gaming
So I have been writing posts on Reddit over the course of the last few months as I have been having lag issues/packet loss/ISP problems... As I thought it was my router/modem initially causing th...
- Aug 04, 2020defiled669 you're on beta firmware, there will be bugs, that is to be expected.
DirtySZN okay that's very interesting, the only other way would be to talk to your ISP and see if they can help adjust your routing for better ping. They will likely be hesitant so perhaps you could say something like your a content creator and that this directly impacts your job - saying it affects your work sometimes prompts them to do something when they otherwise wouldn't.
defiled669
Aug 05, 2020Apprentice
i got a great ping, and the only problem im having on this beta is nothing works at all, had to reinstall old version, waiting for update that was supposed to come this week if i read frazzer right
Netduma-Fraser
Aug 05, 2020NetDuma Partner
No need to keep posting in non beta topics, you will get a new build soon yes. Please post any issues you have just in case we're not aware of them.
