nickstanton
Apr 29, 2018Tutor
Pairing XR500 with a GS810EMX
I currently own an Xr500. I have quickly realized I don't have enough ethernet ports for all my devices as well as the media server and time machine backup I am trying to create would the GS810EMX be...
Netduma-Fraser
Apr 29, 2018NetDuma Partner
There should be no issue using a Switch with the XR500. In terms of which would go best with it any switch that has the amount of ports you need should do the job just fine.
