rdiamond
Jun 25, 2020Follower
Parental controls
I purchased a XR300 recently, and downloaded the NightHawk app. The app says on the App Store there is parental controls available, but my app only shows the Device manager, Speeds, WiFi settings, gue...
Netduma-Fraser
Jun 27, 2020NetDuma Partner
I'm not sure about the app itself but you may need to access the web interface for these. On the interface go to Settings > Advanced Settings > Advanced Wireless and you can control the WiFi schedule there. Device Manager has the network map where you can block devices as you want.
- argonzoJun 27, 2020Aspirant
That's not per-device though, correct? It's blanket policy per WLAN.
- Netduma-FraserJun 27, 2020NetDuma PartnerYes that's right. There will be more powerful controls like that in the next update 3.0. I'd recommend you sign up for the beta if you haven't already so you could give it a try when available http://www.netgearinnovation.com/dumaos-beta/index.html
