rdiamond
Jun 25, 2020Follower
Parental controls
I purchased a XR300 recently, and downloaded the NightHawk app. The app says on the App Store there is parental controls available, but my app only shows the Device manager, Speeds, WiFi settings, gue...
argonzo
Jun 27, 2020Aspirant
That's not per-device though, correct? It's blanket policy per WLAN.
Netduma-Fraser
Jun 27, 2020NetDuma Partner
Yes that's right. There will be more powerful controls like that in the next update 3.0. I'd recommend you sign up for the beta if you haven't already so you could give it a try when available http://www.netgearinnovation.com/dumaos-beta/index.html
