Elliezer
Feb 01, 2021Initiate
passwod re set
how can I get the password that I created during setup that now I forgot. I have a nighhawk r-800 router
Feb 01, 2021Guru - Experienced User
If you setup password recovery, you can use that to recover the login.
if you didn't set it up, it still asks you the questions but there isn't a correct answer.
In that case, you'd need to factory reset it to get back to the defaults.
Elliezer
Feb 02, 2021Initiate
thsnks will try
