Soulgix
Nov 29, 2019Guide
PC XR500 Geo-filter not working
Hi, I just bought a XR500 router. I connected it yesterday to the modem, and it basically installed itself. The only problem I got during the installation was a failed speedtest, but I acepted the su...
- Nov 29, 2019Remove the Device from the Geo-Filter, close down the game and launcher. Change the PC to a PlayStation in the Device Manager and then re-add to the Geo-Filter and launch the game/client. We haven't tested this games specifically as you should be able to select your server in game but that should work in Spectating Mode at least.
Netduma-Fraser
Nov 29, 2019NetDuma Partner
Add the PC as a console to the Geo-Filter and then close the game / client launcher completely and restart it, do you see anything on the map then at all?
- SoulgixNov 29, 2019Guide
Already tried it yesterday but, tried it again right now, the world remains empty
- Netduma-FraserNov 29, 2019NetDuma PartnerDo you have another game to test with on PC to see if it populates? Also these games it may not show anything until you're actually in a game.
I tried inside the game also, but i am installing overwatch right now. As soon as i'm done, i will open the ports and check it
Unlike Fo76 and WoW Overwatch is a game with 12 people inside specific servers, so i hope i'll see something
