Soulgix
Nov 29, 2019Guide
PC XR500 Geo-filter not working
Hi, I just bought a XR500 router. I connected it yesterday to the modem, and it basically installed itself. The only problem I got during the installation was a failed speedtest, but I acepted the su...
- Nov 29, 2019Remove the Device from the Geo-Filter, close down the game and launcher. Change the PC to a PlayStation in the Device Manager and then re-add to the Geo-Filter and launch the game/client. We haven't tested this games specifically as you should be able to select your server in game but that should work in Spectating Mode at least.
Netduma-Fraser
Nov 29, 2019NetDuma Partner
Add the PC as a console to the Geo-Filter and then close the game / client launcher completely and restart it, do you see anything on the map then at all?
Soulgix
Nov 29, 2019Guide
Already tried it yesterday but, tried it again right now, the world remains empty
- Netduma-FraserNov 29, 2019NetDuma PartnerDo you have another game to test with on PC to see if it populates? Also these games it may not show anything until you're actually in a game.
- SoulgixNov 29, 2019Guide
I tried inside the game also, but i am installing overwatch right now. As soon as i'm done, i will open the ports and check it
Unlike Fo76 and WoW Overwatch is a game with 12 people inside specific servers, so i hope i'll see something
PLaying Overwatch now, 6 vs 6, and nothing showing on the map
there is something wrong with the router :(
