Soulgix
Nov 29, 2019Guide
PC XR500 Geo-filter not working
Hi, I just bought a XR500 router. I connected it yesterday to the modem, and it basically installed itself. The only problem I got during the installation was a failed speedtest, but I acepted the su...
- Nov 29, 2019Remove the Device from the Geo-Filter, close down the game and launcher. Change the PC to a PlayStation in the Device Manager and then re-add to the Geo-Filter and launch the game/client. We haven't tested this games specifically as you should be able to select your server in game but that should work in Spectating Mode at least.
Soulgix
Nov 29, 2019Guide
QoS screen
Netduma-Fraser
Nov 29, 2019NetDuma Partner
- SoulgixNov 30, 2019Guide
:O
It worked, i see a white box in the map
- Netduma-FraserNov 30, 2019NetDuma PartnerGreat to hear that, now you can ping it and see the quality of your connection.
- SoulgixDec 01, 2019Guide
I tested these 2 days, i can now see Fallout 76 server and different Overwatch servers with all the ping informations.
I'm signing the solution and closing the issue
thank you for the support
