iMFearzHD
Mar 18, 2020Aspirant
PC XR500 Geo-filter not working
Hi, I connected it yesterday to the modem, and it basically installed itself. The only problem I got during the installation was a failed speedtest, but I acepted the suggested speeds and moved on. I...
iMFearzHD
Mar 22, 2020Aspirant
Hosts don't appear out when I trying load into a match
Netduma_Alex
Mar 24, 2020NetDuma Partner
Just to make sure, i'll run through all of the steps so far to make sure it's not configuration issue:
- Remove all devices from Geo-Filter
- Go to Device Manager, find your PC
- Click the PC, in the side menu, change device type to Xbox, press SAVE
- Return to Geo-Filter, add your PC again
- Now try playing Fortnite and see what happens
- iMFearzHDMar 24, 2020Aspirant
To perform step 3 i need to do this?
check the screenshot- Netduma-FraserMar 24, 2020NetDuma PartnerYes select the Xbox from that drop down list.
