BretD
Apr 20, 2018Administrator
PCGamer: "Best gaming router Netgear Nighthawk XR500" #Review
PCGamer pit the XR500 versus some other great gamer-focused routers in the industry and the XR500 came out on top!
"The Netgear Nighthawk Pro Gaming XR500 is the best gaming router for most ...
Darius68
May 17, 2018Aspirant
When hooking up the nighthawk 3200 everything appears ok all lights turn white when I connect devices it shows strong signal but when I try to open page it says nighthawk blocking any ideas?
- Netduma-FraserMay 18, 2018NetDuma PartnerHi Darius, you'll need to post here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk for any Nighthawk routers that are not the XR500.
Just as a guess though sounds like you may have Block Sites/Services active in Settings.
