Brennan73
Jun 09, 2020Aspirant
PCIe Wireless Adaptor
Hi there, I am experiencing random latency spikes when I play online games, specifically Overwatch. I am not able to connect via ethernet and have to use wireless. I have been working with Blizzard s...
Netduma-Fraser
Jun 09, 2020NetDuma Partner
If the issue is the adapter then yes it would help. Have you done some basic ping tests using command line or PingPlotter for example to see if you see the problem there also?
Brennan73
Thank you for responding. Yes, I have done quite a lot of testing, trial and error, and settings changes. I did run a continuous ping to google.com and when I experienced in game latency it showed a massive spike. Does that mean it's my current wireless adapter?
Also, Blizzard support mentioned this to me after I sent them various test result files:
Going over the system files, I noticed the system uses a wifi adapter to connect online. I also noticed some wifi stability problems as indicated by the following log line:
| 192.168.1.1 - 0 | 348 | 348 | 1 | 9 | 2564 | 1 |
This first hop here is the connection between the computer and the wifi router. The average is about 9 which is super high for in-home networks but not the worst thing in the world. However it's spiking all the way up to 2500+ which is not good.
This latency spike on the winMTR matches up pretty well with the in-game Netgraph reports. The only value that is abnormal is latency in both reports.
- Netduma-FraserJun 10, 2020NetDuma PartnerIt's hard to tell as I don't know what that log line is based on but how far away are you from the router using WiFi and are you using 2.4 or 5GHz?
- Brennan73Aug 06, 2020Aspirant
Sorry to respond to a somewhat older thread and I know there are multiple other threads about the new beta version but I was wondering if someone could look into where I am on the list because I filled out that form quite some time ago. Thank you.
- Netduma-FraserAug 06, 2020NetDuma PartnerWe can't check precisely but we can try and boost you up the list.
