Brennan73
Jun 09, 2020Aspirant
PCIe Wireless Adaptor
Hi there, I am experiencing random latency spikes when I play online games, specifically Overwatch. I am not able to connect via ethernet and have to use wireless. I have been working with Blizzard s...
Brennan73
Thank you for responding. Yes, I have done quite a lot of testing, trial and error, and settings changes. I did run a continuous ping to google.com and when I experienced in game latency it showed a massive spike. Does that mean it's my current wireless adapter?
Also, Blizzard support mentioned this to me after I sent them various test result files:
Going over the system files, I noticed the system uses a wifi adapter to connect online. I also noticed some wifi stability problems as indicated by the following log line:
| 192.168.1.1 - 0 | 348 | 348 | 1 | 9 | 2564 | 1 |
This first hop here is the connection between the computer and the wifi router. The average is about 9 which is super high for in-home networks but not the worst thing in the world. However it's spiking all the way up to 2500+ which is not good.
This latency spike on the winMTR matches up pretty well with the in-game Netgraph reports. The only value that is abnormal is latency in both reports.
Netduma-Fraser
Jun 10, 2020NetDuma Partner
It's hard to tell as I don't know what that log line is based on but how far away are you from the router using WiFi and are you using 2.4 or 5GHz?
- Brennan73Aug 06, 2020Aspirant
Sorry to respond to a somewhat older thread and I know there are multiple other threads about the new beta version but I was wondering if someone could look into where I am on the list because I filled out that form quite some time ago. Thank you.
- Netduma-FraserAug 06, 2020NetDuma PartnerWe can't check precisely but we can try and boost you up the list.
