adameast9000
May 26, 2019Tutor
Philips Hue hub break DHCP address assignment over LAN on NightHawk Router
Recently upgraded from a Nighthawk R7500v2 to an XR500 but the issue is the same on both routers. The router works fine with wired and wireless devices (I have a switch and xbox connected via wired),...
May 27, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Can you set a IP address reservation for the HUE bridge?
Or Try setting a static IP address on the HUE bridge if possible thats outside the routers default IP address pool. You may need to change the routers IP address pool from 192.168.1.2 - .254 to 192.168.1.100 thru .200. This will give you room on either side of the pool for static IP addressed devices.
Netduma-Fraser
May 28, 2019NetDuma Partner
Could you upgrade to this firmware and see if it resolves the issue please? https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
