adameast9000
May 26, 2019Tutor
Philips Hue hub break DHCP address assignment over LAN on NightHawk Router
Recently upgraded from a Nighthawk R7500v2 to an XR500 but the issue is the same on both routers. The router works fine with wired and wireless devices (I have a switch and xbox connected via wired),...
adameast9000
Jun 04, 2019Tutor
There is no ethernet switch in the config. The HUE hub directly connects to the router via eithernet. I configured a smaller DHCP range and set the HUE to a static address outside that. I saw no issues for a few days but last night the same issue again where wired devices were dropped from the network at the same time, and then could not receive a new IP via DHCP until rebooting the router. Will try updating the firmware with the hotfix mentioned in the other comment and see how that goes.
Thanks for all help so far.
Netduma-Fraser
Jun 05, 2019NetDuma Partner
Keep us updated on how the firmware works out!
