Amocat
Jun 15, 2021Follower
Phillips HUE wont pair, similar issues reported but dont see a solution
I have a hue bridge, now my 3rd with the same issue: The Hue app doesnt seem to have a satble connection to the hie bridge. The bridge must be connected via ethernet, and the app on that same routers...
Jun 16, 2021Guru - Experienced User
. When trying to connect the apop to the Hue a physical button must be pressed, but there is no response in the hue app. I
A button on the hue bridge must be pressed?
My understanding of the Hue is that its creates its own wireless network from the hue bridge for the bulbs to connect to.
What modem/gateway is the XR connected to?
BertAnsink
Jun 29, 2021Guide
Sort off. It uses Zigbee protocol and forms a mesh, the hue lights can forward the signal for other bulbs as well.
I have used Hue bridge on both the XR500 and XR700 and never had an issue with it. I have the gen 2. bridge though, but if you have changed yours out a few times you probably also have generation 2. I have it plugged straight in the router, not through any switches and so on.
I do give it a static IP reservation in the DHCP table since you can't set a static IP on it, at least not as far as I know.
If you know the IP of your hue bridge, type it in your browser and see if it's reachable. If that works, there is no reason your app can't communicate with it. You need the original Hue app to sync and set it up I believe. But if that has been done before you can also use a PC app like Huetro and see if it works over that.
