apparii
Jan 08, 2021Tutor
Phone calls and text messages don’t work when connected to WiFi?
For some reason 5G and 4G devices have failed calls and text messages on my home network. Any setting changes or suggestions?
apparii
Jan 08, 2021Tutor
Using the Nighthawk XR500
Netduma-Fraser
Jan 08, 2021NetDuma Partner
Okay so I assume you're using WiFi calling? Are you using Smart Connect? If so disable this and connect to 2.4 or 5GHz manually and then see if it behaves better.
- appariiJan 08, 2021TutorSmart connect is not enabled. Thanks for the idea to check, though. WiFi calling is set up on all devices. Not sure why SMS/MMS messages don’t go through to Android users.
- Netduma-FraserJan 09, 2021NetDuma PartnerIn WAN Settings toggle SIP ALG and see if that helps please.
- appariiJan 11, 2021TutorUnfortunately that did not fix the issue with failed calls.
