HelppMee
Jul 27, 2019Aspirant
Ping and download speed the same as modem?
There is no difference in my internet speed or ping on my xfinity modem compared to my nighthawk xr500 router the only thing different I can do is connect the nighthawk xr500 router to the closest ser...
Netduma-Fraser
Jul 27, 2019NetDuma Partner
A router won't give you higher speeds, that's down to your ISP. It can't lower your ping to a value that you want as it's dependent on other variables. What it can do is allow you to have the best connection possible for your situation and it sounds like it is working. I'd recommend taking a look at this guide to optimise your settings: http://support.netduma.com/en/support/solutions/folders/16000090646
- HelppMeeJul 27, 2019AspirantThanks I have a double nat on my Xbox it says I am connect but how do I fix it?
- Netduma-FraserJul 27, 2019NetDuma PartnerTake a look at the Open NAT guide from the link I gave you and that should resolve it.
