heroxoot
Aug 05, 2019Apprentice
Ping assist doesn't work.
I turned on Ping assist, set it to 60, and it still lets peers connect to me that are well above this threshold. What gives?
heroxoot
Aug 19, 2019Apprentice
I understand they are the same besides a slightly less powerful 2.4ghz band. Everything else is identical. However I believe putting XR500 firmware might not work or cause a brick. I could be wrong but that be my experience with past routers with identical hardware but different names.
But yes, I believe they came to the concolusion on the NetDuma forum it's related to SFV. You can see the thread here.
https://forum.netduma.com/topic/29120-ping-assist-problems/
In fact you participated in it.
Netduma-Fraser
Aug 20, 2019NetDuma Partner
We'll post back in the Netduma topic as it's easier with the pictures you have provided.
