Compoza_
Mar 09, 2021Luminary
Ping assist doesn't work at all
As the image shows, I have set ping assist to 20 ms and put the Geo filter point in the ocean and still puts me into matches above 20 ms. It had put me in to African server dispate the ping assist an...
- Mar 09, 202120ms may be too low for you to get a game which is why it is getting games slightly higher, it may be best to instead use the radius exclusively to force the servers closest to you.
Netduma-Liam
Mar 09, 2021NetDuma Partner
What game are you seeing this issue in? Could you please ensure you have filtering mode enabled?
Compoza_
I have factory resettet the router and still doesn't work. I'm gonna try to downgrade the firmware to see if it helps.
- Netduma-FraserMar 09, 2021NetDuma Partner20ms may be too low for you to get a game which is why it is getting games slightly higher, it may be best to instead use the radius exclusively to force the servers closest to you.
