jose13lilt
Mar 06, 2021Tutor
ping assist not working warzone
I have the xr500 with version 2.3.2.114-DumaOS3.0.203, I follow the guide https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/What-is-Ping-Assist/mp/1698092#M7863 and It does not work for m...
jose13lilt
Mar 07, 2021Tutor
jose13lilt
Mar 07, 2021Tutor
the heatmap says that I have that ping, if I restrict the zone as I show you, the ping I have in the game is 80-120
https://ibb.co/F3R5GpL
I don't have the ping that the heatmap says, I don't know why, but if I deactivate the geo filter I have ping of 40-60ms
- Netduma-FraserMar 07, 2021NetDuma PartnerAuto Ping should ping the server you're in on the Geo-Filter, if you scroll down you should then be able to see it. I'm really interested to know what the Geo-Filter says because if it is a lot lower then it indicates the server is under heavy load and would be best to force another that may perform better.
- jose13liltMar 07, 2021Tutor
Netduma-Fraser wrote:
Auto Ping should ping the server you're in on the Geo-Filter, if you scroll down you should then be able to see it. I'm really interested to know what the Geo-Filter says because if it is a lot lower then it indicates the server is under heavy load and would be best to force another that may perform better.- Netduma-FraserMar 07, 2021NetDuma PartnerOkay that's really good so it sounds like the server itself, turn Ping Assist to 0 and move your home location and radius to try and force some other servers in Europe.
