jose13lilt
Mar 06, 2021Tutor
ping assist not working warzone
I have the xr500 with version 2.3.2.114-DumaOS3.0.203, I follow the guide https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/What-is-Ping-Assist/mp/1698092#M7863 and It does not work for m...
jose13lilt
Mar 07, 2021Tutor
Netduma-Fraser
Mar 07, 2021NetDuma Partner
Move it more over to the right excluding the UK/Top of France and reduce the radius to 750km
- jose13liltMar 07, 2021Tutor
in this way it keeps looking for a game infinitely, restart the game, so the configuration remains
https://ibb.co/sb6sVz1 - Netduma-FraserMar 07, 2021NetDuma Partner
Turn off the game/quit the game completely then try this area by drawing a polygon then wait 2 minutes and boot it up. It does look like it is working correctly from the screenshot
- Netduma-LiamMar 08, 2021NetDuma Partner
You'll need to have filtering mode enabled for Fraser's suggestion to work for you, please toggle that and search again!
- jose13liltMar 08, 2021Tutor
was activated, deactivated it to be able to play
How do I get the beta version of dumaos for my xr500?
I also can't get open nat in warzone, in cod cold war yes, but not in warzone
- Netduma-LiamMar 09, 2021NetDuma Partner
Could you please remove your device from Geo-filter, go to Device manager and click on your PC then change it's device type to Playstation, then re-add the device to Geo-filter.
You can find beta versions of DumaOS in this sub-forum: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
It's odd that you'd get an Open NAT in Cold war but not Warzone, do you also experience this with Geo-filter disabled? Is it having any affect on your matchmaking?
- jose13liltMar 09, 2021Tutor
no, it has no effect, what I put the device as playstation I already did, I emptied the cloud, what I am trying is to search for game and block the server one by one, but it seems that they are infinite, I have a huge list of dedicated servers in france blocked but they keep appearing, giving 70 ms,
What I don't understand is that in dumaos it tells me that it gives 23ms but in options game -> account gives 70-98ms at least 60mshttps://ibb.co/jL0bG0c
https://ibb.co/9WCLYDs
https://ibb.co/mTwwspv
https://ibb.co/3TQNhGx - Netduma-FraserMar 09, 2021NetDuma PartnerYou have too many options enabled to get an open NAT which can actually achieve the opposite affect. Remove the port forwarding rules and the DMZ, just leave the NAT option as open. The ping in game includes things like processing delay, if it is much higher then it indicates the server may be under load and trying to get other servers may be beneficial.
It only finds me in France and that's it, I can't lower the ping, before with the isp router I had better ping,
I will try what you tell me about the nat and tell you if it works for me
I got my nat to be open, but I can't get a good configuration to improve my latency, I'm beginning to think that I didn't do well to buy the xr500, because apart from the geo filter I don't see any use for it, with the isp router from time to time in when I was starting at 35ms, that's why I got this router,
So that it always connects to that server, if I restrict the area to Spain where the server that gives me 11ms is, it never finds a game, I don't know what else to try, because on top of that, having the geo filter activated taking Spain and part of a large part of France I get games minimum 70ms and maximum 120ms,
but the SBMM breaks and finds me games twice my levelhttps://ibb.co/mbmWKFH
https://ibb.co/d7CkY5q
https://ibb.co/wgnVk32 - Netduma-FraserMar 09, 2021NetDuma PartnerYou need to move the radius/home location to exclude Spain and the top of France and cover the rest of the EU, you're getting a lot of good pings showing on heatmap
- jose13liltMar 10, 2021Tutor
doing it this way becomes impossible to enter a lobby
- Netduma-FraserMar 10, 2021NetDuma PartnerThere are a lot of servers within that polygon so shouldn't be an issue getting a game. Did you adjust those settings when you were already on the game?
I adjusted it being inside and then outside, but nothing, it does not work, instead a server from the USA jumps
- Netduma-FraserMar 10, 2021NetDuma PartnerDo this please:
Hard turn off the console
Remove device from Geo-Filter
Flush cloud from Geo-Filter Map menu
Re-add the device to the Geo-Filter
Setup the Geo-Filter how you would like
Wait 2 minutes
Boot up the client/game - jose13liltMar 10, 2021Tutor
it has not worked
I can't get the geo-filter to work, maybe activision no longer lets you use the geo-filter
- Netduma-FraserMar 10, 2021NetDuma PartnerThe filter is definitely working in that screenshot, the Spain server is not always available. Please try the steps I said and set it up according to the polygon previously
what polygon?
- Netduma-FraserMar 10, 2021NetDuma PartnerThis one you linked: https://ibb.co/Z60cJvR
- jose13liltMar 11, 2021Tutor
still not working
- Netduma-LiamMar 11, 2021NetDuma Partner
What are you seeing now? How long is it taking to get a game? Did you try installing the firmware?
- jose13liltMar 12, 2021Tutor
Yes, it didn't work and I went back to the latest version with dumaos 3.0.204
