jfuaito's avatar
jfuaito
Ping GS108PEv3 dropped packets
My GS108Ev3 switch and MacBook connected directly to Nighthawk Pro Gaming Router X500. When Ping from my MacBook to the switch, some packets were dropped. Mostly reach approximately icmp_seq 1000 then will see some packets dropped. I had tried to connect the switch from port 1 to 8 to the router's port 1 and continue to Ping respectively but still will get some packets dropped. Is there any correct or recommendation to connect the switch port to router's port? For example, using the switch's port 1 to router's port 1. Both switch (V2.06.03EN) and router ( V2.2.1.10) are using the latest firmware version.
    • TheEther's avatar
      TheEther
      Guru
      Personally, I would not worry too much about the occasional dropped packet when directly pinging the switch. The switch's CPU is probably really slow. The CPU should not involved in switching packets. It would be more useful to ping a device connected to the switch.
      • jfuaito's avatar
        jfuaito
        I think this should be correct that the switch itself response delay. I had tried pinging all three devices which connected to the switch until icmp_seq more than 2000 and none of the packets were lost.
    • jfuaito's avatar
      jfuaito
      This should be benefit to know and understand.
