longr5310
May 09, 2023Aspirant
PING HeatMap Will Not Load
Hello, Even after sync up the cloud three times on Geo filter, the Ping Heatmap will not load. On the heat map page what comes up is Force Update. This will also not work...in addition the DUMAO...
Netduma-Fraser
May 09, 2023NetDuma Partner
It's something we're looking into currently, it will be an issue with the cloud, nothing you need to do on your end for the moment
