Victormtz
Dec 25, 2022Aspirant
Ping heatmap
Anyone know why when I use pingheatmap on cod I only get one ping server and no ping of the other servers
michaelkenward
Dec 26, 2022Guru - Experienced User
You own a Netgear device of some sort?
I has Netgear firmware? (Which version?)
Anything else you'd like to add that might explain what you are doing and what you want to know?
Victormtz
Dec 26, 2022Aspirant
I have a NETGEAR nighthawk xr1000 pro gaming and system version is 10.0.64_1.049 the problem I have is when I tried to search for ping heatmap for mw2 it shows me nothing on the map
- michaelkenwardDec 27, 2022Guru - Experienced User
Victormtz wrote:
I have a NETGEAR nighthawk xr1000 pro gaming and system version is 10.0.64_1.049OK. The gaming stuff has its own experts, including the people who support the DumaOS operating system. Maybe they can help.
- VictormtzDec 27, 2022AspirantWhere can I find DumaOS community?
Victormtz wrote:
Where can I find DumaOS community?Here, in the section given over to Nighthawk Pro Gaming.
They are usually very quick to respond, but in the holiday season may now be quite as active as usual.
In the meantime you could try this:
Search - NETGEAR Communities – heatmap
Adding some more details of what is happening at your end might also be useful.
