Victormtz
Dec 25, 2022Aspirant
Ping heatmap
Anyone know why when I use pingheatmap on cod I only get one ping server and no ping of the other servers
Victormtz
Dec 26, 2022Aspirant
I have a NETGEAR nighthawk xr1000 pro gaming and system version is 10.0.64_1.049 the problem I have is when I tried to search for ping heatmap for mw2 it shows me nothing on the map
michaelkenward
Dec 27, 2022Guru - Experienced User
OK. The gaming stuff has its own experts, including the people who support the DumaOS operating system. Maybe they can help.
- VictormtzDec 27, 2022AspirantWhere can I find DumaOS community?
- michaelkenwardDec 27, 2022Guru - Experienced User
Victormtz wrote:
Where can I find DumaOS community?Here, in the section given over to Nighthawk Pro Gaming.
They are usually very quick to respond, but in the holiday season may now be quite as active as usual.
In the meantime you could try this:
Search - NETGEAR Communities – heatmap
Adding some more details of what is happening at your end might also be useful.
- Netduma-FraserDec 27, 2022NetDuma PartnerIt needs a cloud update which we'll do as soon as we can, it will not affect your ability to use the Geo-Filter to connect to the best/lowest ping servers.
