Consumer0129383
Apr 24, 2020Luminary
PING, LATENCY, VERY POOR ONLINE GAMING EXPERIENCE
Posted a image showing what my connection is like in pretty much every online game one PS4 Pro ecspecially Call of Duty games. Can someone tell me why my connection is consistently like this? I h...
Netduma-Fraser
Apr 25, 2020NetDuma Partner
It's very hard to tell whether that is good or bad as there is no scale. Are you using QoS and the Geo-Filter? What is the average ping you're seeing to the game on the Geo-Filter?
- Consumer0129383Apr 25, 2020Luminary
This is bad! the ping is all over the place. When I'm having no problems my ping is relatively stable barley any deviation at all (flucuations between 2-3 points from the low end). I've used Qos, I've disabled it and I've done that with Geo-Filter as well. When there are no problems which is rare I see an average ping of 20-30ms. But 80% of the time I see dramatic fluctuation of 30ms up to 100+ms back down again. Not to mention getting killed instantly, hit detection being iffy, slow movement, and enemies just appearing in front of me.
- Netduma-FraserApr 26, 2020NetDuma PartnerWhat is the scale on that picture? Where are you seeing those fluctuations, on the game reading or on the Geo-Filter? What QoS settings have you used so far? Are you connecting to the closest server with the Geo-Filter?
- Consumer0129383Apr 26, 2020Luminary
What is the scale on that picture? Whatever scale Call of Duty Black Ops 4 uses.
Where are you seeing those fluctuations, on the game reading or on the Geo-Filter? Those readings are on the game. You don't see the connection meter for a game/match on the Geo-Filter all you see is the number for the ping.
What QoS settings have you used so far? I've used them all and I have shut them all down. It doesn't seem to do anything at all.
Are you connecting to the closest server with the Geo-Filter? Yes. When I have the Geo-filter active it takes much longer to find a match and it is always with in the radius. But, some of the closest servers are the worst. There is one in Oklahoma that is absolute trash 123ms+.
Here is an image of what it should look like (although the game play was still extremely laggy).
